  1. I compiled a home video with a menu and cool bottons i made in DVD lab. I used 2 audio streams and i followed the guide on the left side, but the output DVD does not contain an IFO file , what's going on? the compile process finishes without any problems. please help me
    dvd-lab 1.31
  2. for those of you still wondering that dvdlab doesn't create an IFO file is because you can only have all your audio and video the same format
  3. Try using the newest version of DVD-Lab(1.4 beta1). It allows for multiple VTS, which then allows you to have different ausio types and different video resolutions onthe same DVD.
  4. I had that problem, but found becasue i didnt have a back ground for my menu just a couple of imported pictures to use as links instead, it went through the whole process fine but it didnt create the ifo files until i had put a background on for some reason.
