I AM NEW TO THAT I JUST STATERD ON WIN XP .
BEFORE TO BUY THAT .I NEED SOME ANSWER PLEASE .
LIKE : TO CD/DVD AUDIO mp3 ,wav ,DATA BACK-UP,VIDEO CD (VCD,SVCD) ETC.
WICH ONE :
NERO 6 ?
EASY CD CREATOR ( BUT SOME PEOPLE DON T LIKE THIS ONE) ?
ULEAD DVD MOVIE FACTORY 3 ?
ALCOHOL 120% ?
CLONE CD ?
RECORD NOW DELUXE ?
CDRWIN ?
OR WICH ONE ?
THANK S
Results 1 to 9 of 9
PLEASE STOP SHOUTING! We're not deaf.... Uhh, anyway... Capitals are SHOUTING. Please don't do it!
With regards to your question, it's really up to you to decide this. I like Nero because it's quite simple to use, but I have used CDRWin in the past and this prove competant, even if the user interface isn't brilliant.
You can download trial versions of all these packages. Give them a shot, see which you like the best and go for it!
CobraDMX -
I know there are lots of Nero haters, but I use Nero almost exclusively
now for burning audio CD's, MP3 CD's, DIVX and XVID (which I play in
the Liteon LVD 2001), VCD's, SVCD's, BIN files, and DVD's. -
For CD's Nero 5.5 is great and you can probably pick it up online for <$50 CAN.
www.pricegrabber.com
I prefer using RecordNow Max for DVD's.
http://estore.sonic.com/enu/dmd/recordnowmax.asp?lang=enu -
Been doing this for years, and refuse to use anything but Nero... I take that back, ive also used Alcohol 120 for burning images.
I like Sonice Recordnow DX which came with my Lite-On 411s. In my opinion you should stick to whatever burn program came with your burner because that is the recommended one.
Can you help me to decide wich software to buy from the following?
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2011, 09:05 -
MKV to IPOD conversion with the audio track that I choose. Wich software?
By fgtan in forum Video ConversionReplies: 5Last Post: 15th May 2010, 00:09 -
Best software to burn my dvd files
By superJT in forum Authoring (DVD)Replies: 10Last Post: 18th Aug 2008, 21:35 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46 -
I have a Denon DVD 3800, wich software and dvd-media do you use
By xsienix in forum DVD & Blu-ray PlayersReplies: 10Last Post: 25th May 2007, 16:10
