Hi, my player has just given up. It opens and shuts ok but when I try to play a disc and it starts to read it, it only gets as far as the first 0 and does not read any further. There is a small red square with a B in it which is always on and lit and I can't remove it. Also after some 15 seconds a code comes on. It is HO7. Pulled plug from back and scart connected ok. Tried with discs it will accept but will still not go any further in the read cycle. Anyone know the fault code and how to remedy. Thanks 2cvtools.
Results 1 to 1 of 1
Panasonic SA-PT22 region free codes
By ys1ms in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2011, 14:26 -
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 02:00 -
Panasonic DMR-E100 or E100H unlock codes to make region free
By Johnmunch in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Apr 2010, 16:58 -
Is VLC a fault-INtolerant VOB PLAYER for pre-DVD-burning quality testing?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 5Last Post: 16th Aug 2009, 21:52 -
Quicktime: native codes in Apple QT player?
By geneaum in forum Software PlayingReplies: 1Last Post: 12th May 2009, 09:02
