Hey.. I converted a xvid to svcd this night, using DVD2SVCD. Before i clicked convert, i clicked conversion -> add external subtitles, and pointed at my SRC file. But i dont see the subs in the final mpg files.? Is it normal, will u only see them when playing bac on dvd? The SubLog files are also there. The info file is here :
WNASPI32.DLL 0.0.0.0
- 14-01-2004 22:42:01
- AVI to SVCD Conversion
- AVI2SVCD ver. 1.2.1 build 3
Initializing
- \\Tynor-server\SharedDocs\dmd-ttcmscr.avi
Initializing finished.
Saving Subtitles ini file
- 14-01-2004 22:42:07
- Free on drive C: 5718.51 mb
- AUDIO Extraction
Audio extraction finished.
- 14-01-2004 22:43:13
- AUDIO conversion
- 14-01-2004 22:43:14
- AUDIO conversion
Converting MP2 to WAV. Filename: C:\Programmer\DVD Ripping\DVD2SVCD\Movie\Extracted_audio_1.mpa
Executing MADPlay (mp2 to wav). Commandline:
"C:\Programmer\DVD Ripping\DVD2SVCD\MADPlay\madplay.exe" --quiet --output=wave:"C:\Programmer\DVD Ripping\DVD2SVCD\Movie\Encoded_audio_1.mp2.wav" "C:\Programmer\DVD Ripping\DVD2SVCD\Movie\Extracted_audio_1.mpa"
Conversion (mp2 to wav) of C:\Programmer\DVD Ripping\DVD2SVCD\Movie\Extracted_audio_1.mpa finished.
Encoding Audio. Filename: C:\Programmer\DVD Ripping\DVD2SVCD\Movie\Extracted_audio_1.mpa
Executing BeSweet. Commandline:
"C:\Programmer\DVD Ripping\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Programmer\DVD Ripping\DVD2SVCD\Movie\Encoded_audio_1.mp2.wav" -output "C:\PROGRA~1\DVDRIP~1\DVD2SVCD\Movie\Encoded_audio _1.mp2" -logfile "C:\PROGRA~1\DVDRIP~1\DVD2SVCD\Movie\Encoded_audio _1.log" ) -ota( -g max ) -shibatch( --rate 44100 ) -2lame( -e -b 192 -m s )
Audio conversion of C:\Programmer\DVD Ripping\DVD2SVCD\Movie\Extracted_audio_1.mpa finished.
Audio conversion finished.
- 14-01-2004 23:14:29
- Free on drive C: 5718.48 mb
- Video Encoding using TMPGEnc
- Encoding C:\Programmer\DVD Ripping\DVD2SVCD\Movie\AviSynth_Script_file.avs
StreamSectors: 1543075576
AudioSectors: 137627280
VideoPAPO: 21771144
ScanOffsetBytes: 127213
SeqAligningBytes: 8085106
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 0.00
PureMPEGStream: 1375464825.20
Seconds: 5657.92
CalcMPEGStream: 1375464825.20
Frames: 141348
CDSize: 740.00
Number of CDs: 3
Cut point 735.00
Max. Bitrate: 2530
Avg. Bitrate: 2000.00
Min. Bitrate: 300
Executing TMPGEnc. Commandline:
"C:\Documents and Settings\SERVER\Skrivebord\thonas\TMPGEnc-2.521.58.169-Free\TMPGEnc.exe" "C:\Programmer\DVD Ripping\DVD2SVCD\Movie\TMPGEnc_Project_file.tpr" /Encode /Close
Video Encoding finished.
- 15-01-2004 12:03:01
- Free on drive C: 4681.47 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Programmer\DVD Ripping\DVD2SVCD\bbMPEG\default.ini
- 15-01-2004 12:03:05
- 15-01-2004 12:03:08
- 15-01-2004 12:03:11
- Multiplexing and cutting
Offset in Seconds: 5
Executing bbMPEG.
Variable Settings:
Movie offset: 5 seconds
Cut point: 735 mb
Executing RunbbMPEG. Commandline:
"C:\Programmer\DVD Ripping\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Programmer\DVD Ripping\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg"
Length of C:\Programmer\DVD Ripping\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
2712 Seconds
Offset in Seconds: 2717
Executing bbMPEG.
Variable Settings:
Cut point: 735 mb
2819 Seconds
Offset in Seconds: 5536
Executing bbMPEG.
Variable Settings:
Cut point: 735 mb
Multiplexing and cutting finished.
- 15-01-2004 12:34:06
- Free on drive C: 3177.22 mb
- Determining length of audio
Analyzing: C:\Programmer\DVD Ripping\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
2714.567 seconds C:\Programmer\DVD Ripping\DVD2SVCD\Movie\bbMPEG_Muxed_File00.mpg
Analyzing: C:\Programmer\DVD Ripping\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
2821.956 seconds C:\Programmer\DVD Ripping\DVD2SVCD\Movie\bbMPEG_Muxed_File01.mpg
Analyzing: C:\Programmer\DVD Ripping\DVD2SVCD\Movie\bbMPEG_Muxed_File02.mpg
117.499 seconds C:\Programmer\DVD Ripping\DVD2SVCD\Movie\bbMPEG_Muxed_File02.mpg
Analyzing finished.
Saving Subtitle Timecodes.
SVCD subtitles.
2714
Length of C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\bbMPEG_Muxed_File01.mpg
2821
Length of C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\bbMPEG_Muxed_File02.mpg
117
- 15-01-2004 12:36:20
- Free on drive C: 3169.25 mb
- Multiplexing SVCD Subtitles
Muxing Dansk subtitles, CD 1
Executing SubMux. Commandline:
"C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\WinSubMux\[removeme]WinSubMux[removeme].exe" "C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\bbMPEG_Muxed_File00.mpg" -l "C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\SubLog1.txt" -s0 "C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\da1-1.sub" "C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\bbMPEG_Muxed_File-subbed00.mpg"
Muxing Dansk subtitles, CD 2
"C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\[removeme]WinSubMux[removeme]\[removeme]WinSubMux[removeme].exe" "C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\bbMPEG_Muxed_File01.mpg" -l "C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\SubLog2.txt" -s0 "C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\da1-2.sub" "C:\Programmer\DVD Ripping\[removeme]DVD2SVCD[removeme]\Movie\bbMPEG_Muxed_File-subbed01.mpg"
Muxing subtitles finished
Image creation finished.
- 15-01-2004 12:53:45
- Free on drive C: 1660.89 mb
- Conversion done!
Does your player support SVCD subs? Not many that do... And even fewer (if possible) software SVCD players. What did you play the mpeg with?
/Mats -
Windows Media Player.. I didn't try on a normal DVD player.. So it's normal it doesn't works on software dvd players? Like Power DVD?
Originally Posted by demon_
I just tried on a DVD player.. And they still don't show.. My m8 has also other SVCD movies, and they work with Subtitles.. So i must of done something wrong when muxing?? What can it be.. Maybe i should pick permanent subtitles instead of SVCD subtitles or what? Any ideas?
Yes, for any kind of compatibility, do permanent subs. The # of players that support selectable (SVCD/CVD subs is not that great...) The discs where the subs worked, was that with SVCD subs or permanent subs? Was it on the same player where your SVCD subs wont show?
/Mats -
They havn't worked at all yet =).. So i need to encode the XviD from the beginning and do permanent subtitles (
) Or can i do it without encoding from the beginning? The SVCD movie is in 2mpg files, and the subtitles in 1 srt...
For permanent subs, recoding is unfortunately required...
/Mats
Adjusting xvid Soft Subs Size for dvd player?
By spiritgumm in forum SubtitleReplies: 7Last Post: 27th Jun 2010, 12:39 -
Trouble adding permanent subtitle to xvid, subs don't break right
By boblydan in forum SubtitleReplies: 8Last Post: 18th Jul 2008, 19:53 -
Vista beginner needs help with video conversion! Xvid to VCD with subs
By Joakim_A in forum Video ConversionReplies: 2Last Post: 23rd Sep 2007, 02:59 -
want to add forced subs to divx/xvid files
By gossipninja in forum SubtitleReplies: 3Last Post: 23rd Jul 2007, 03:26 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
