I have got a Hauppage WinTV card, but I am trying to figure out the best way to capture from TV. I have tried various capture software, but nothing seems to do what I want to do - capture from TV for burning to DVD at a decent quality.
Ulead Video Studio won't let me capture at resolutions above 352x288, even if I set it to capture at 720x576 it captures at the lower resolution and then blows it up on export giving poor picture quality.
Adobe Premiere seems to have a problem synching audio and video - It starts off being in synch then gets more and more out of whack the longer I capture (only 2 frames were dropped over the whole 50min capture).
The WinTV2000 bundled software seems to either give really low quality (with whatever codec I try) or drops 1000's of frames when uncompressed.
My system is a AMDXP 1.8GHz, 512Mb DDR RAM - surely this should be good enough to capture at a decent rate?
I did have a ATI AIW Radeon, which captured beautifully in MP2 format, but I bought a high-end graphics card (9700Pro) so I had to take it out.
Is there anyway I can still use the capture device on this card ONLY (it's a PCI card) and use my 9700Pro?
Hope I didn't bore you guys too much.
"I'm The Dude, man. So that's what you call me. Either that or Duder, His Dudeness or El Duderino if you're not into that whole brevity thing."
I don't see any reason why you should not be able to have two graphics cards in the same box. Windows supports it, and if you put a monitor on the second card windows will use it as extra desktop area. There is one note of caution here though - I had some trouble downgrading from one version of an ATI card to another once, and I was quite sure that what had happened was that some of the dll's provided by ATI were card specific instead of being multifunction. So - you might have a software conflict with two incompatable sets of ATI software on your system.
When I had an old Hauppage WinTV card in my system I captured to DivX with no dropped frames. Their newest software will use any codec that you have installed.
Capturing from Hauppage USBLive2 WinTV device !!!
By imperialguy in forum Capturing and VCRReplies: 0Last Post: 23rd Jun 2011, 16:13 -
Converting Hi8 for Mac using Hauppage WinTV PVR USB2?
By eamann in forum MacReplies: 7Last Post: 6th Aug 2009, 14:37 -
Hauppage WinTV, BTWinCap to Vdub, dropping frames
By elvisish in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 11:03 -
Blue screen when installing Hauppage WinTV 150 drivers from website
By ponyboy in forum Capturing and VCRReplies: 1Last Post: 5th Mar 2008, 22:55 -
Color Bleed on Hauppage WinTV-PVR 150
By TheBladeRoden in forum Capturing and VCRReplies: 3Last Post: 14th Jun 2007, 09:05
