I have been trying to convert at DivX movie to a smaller resolution so it fits my PDA using virtual dub.
Even though I change the resolution to 280x320 pixels, the file has the same file size (about 650 mb) as the higher resolution movie.
How can I make the movie get a smaller file size so it fits my memorycard.
Maybe the only way is to change the bitrate, but will this now give a lower quality picture, even though the resolution also is getting lower.
sorry for my bad english. If you guys could link me to some guides, because I can't seem to find any that can help me.
Preps
Yes, only bit rate affects file size (for movies of equal length). But, using a lower resolution allows you to lower the bit rate without losing "quality" (more than the resolution reduction).
/Mats
Good file size when converting TV DVD eps to Xvid/DivX
By ryangarfield in forum DVD RippingReplies: 1Last Post: 28th Apr 2009, 11:06 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Avi not divx-supported size?
By chirufan in forum SubtitleReplies: 21Last Post: 8th Mar 2008, 05:35 -
Different DIVX codec, different output size.
By DonGallego28 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2008, 10:08 -
XviD and DivX file size
By timmer545 in forum Video ConversionReplies: 2Last Post: 9th Nov 2007, 16:30
