    Feb 2002
    Leicester England
    Help
    I have used VCDGear to convert to .bin files to Mpg and both work correctly.
    I have used TMPGenc to convert the first Mpg to adjust for screen size etc and that worked great and have the moded Mpg.
    When I came to do the second Mpg TMPGenc will not load it up saying its invalid or not supported.
    WHY?
    I can watch the file and it plays normally. Is there any software out there that can tell me whats wrong? Is there another way of converting the .bin file?
  2. Member daamon's Avatar
    Melbourne, Oz
    Hey MarkJL,
    Check out this link:
    https://www.videohelp.com/tmpgenc.htm#problems
    The topmost error sounds like your one.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    Feb 2002
    Leicester England
    Well spin my nipple nut and send me to Alaska. I'll give TMPGenc Plus a go.
    Just confused the hell out of me when it encoded cd1 but not 2.
  4. Member daamon's Avatar
    Melbourne, Oz
    Ah, another Red Dwarf fan... Good chap, Mr Lister Sir.
    Hope it works. Let us know how you get on.
    Carpe diem.
    Feb 2002
    Leicester England
    Nope Didn't work still the same message.
    The only way I can get the file to load up is to de-multiplex it, but then I have a audio sync problem.
    Tried ripping the Audio with Vdub and the audio sync is better but it is still out.
  6. Member daamon's Avatar
    Melbourne, Oz
    Mmm... Sorry mate. Stumped - We're now heading outside of my (limited) knowledge and experience.
    It could be your source file.
    Sorry I couldn't be of more help. Good luck...
    Carpe diem.
    Feb 2002
    Leicester England
    Not that I like to admit defeat but I think I'll just create a VCD this time from the bins.
  8. Member daamon's Avatar
    Melbourne, Oz
    Hi MarkJL,
    I know your problem's with TMPGEnc and the second file, but (for making (S)VCD's) check out VCDEasy too. I've not used VCDGear, so can't compare.
    Good luck.
    Carpe diem.
