  1. I got Dish Network with one of those PVR units. I like to transfer some of my favorite shows to my computer for burning onto DVD or just keeping on the hard disk as video files.
    I assume that the PVR encodes the digital signal into an MPEG2 file for storage. When I open a new project (using Vegas 4) I set it up as an AVI for DVD. Is this hurting the quality of the video? Should I just bring it into an MPEG2 project?
  2. Member lgh529's Avatar
    Apr 2003
    Syracuse, Utah, USA
    I have this exact setup and have not found a way to 'download' the stored file from the PVR to my PC. I just have to capture the video using the analog S-video out. This of course means that a compressed mpeg file is converted to analog, then my capture card converts it back to digital.
    Is there loss? You bet, but the average person wouldn't be able to tell.
  3. That makes sense. I was thinking that since it goes from one digital source to the other that it was more of a transfer than a capture.
    I guess it would convert it to analog to go over the S video though. So it doesn't matter how I capture it there will be loss involved when the signal is converted from MPEG2 to analog.
    Thanks for the help.
