running winxp with 512mb RAM, 900mhz, and microadvantage 4x DVD+-RW, went to it website and it said to flash with it latest f/w for media compatibility issue. b4 the flash i can only write at 1x or 1.3x max with any media capable at writing at 2x or 4x. After the flash, i can write up to 4x with no problem, but 1/3 or 1/2 through the burning process, i get either system crash and reboot OR beginning dump of physical memory..
stop: 0x00000008E (0x00000005,.....)
i thought the memory was bad, replace the memory no go. Not sure what to do now.
btw, if i write at 2x now, it will last longer in the burning process b4 it crash or mem dump b.s. that if i was burning at 4x
Any suggestion or solution would really appreciated. thanks in advanced.
Results 1 to 1 of 1
First post here and first time here (surround sound system help) Plz
By Izzdan in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2010, 01:13 -
System Crash
By maximusbob in forum SVCD2DVD & VOB2MPGReplies: 22Last Post: 10th Dec 2007, 20:09 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38 -
plz help my dvd audio is always cracking in my home theater system.
By rex2745 in forum Newbie / General discussionsReplies: 11Last Post: 24th Jul 2007, 05:10 -
Pioneer DVR112d maybe faulty won't read dvdrs and makes system crash!!
By rockonvidtrade in forum DVD & Blu-ray WritersReplies: 12Last Post: 9th Jun 2007, 03:44
