Can anyone help? I have a XVID file that I am trying to put on DVD. FPS is 23.976 which makes it a SVCD, doesn't it? The audio is MPEG Frauenhofer which I convert to wav using Virtualdub Direct Stream & likewise the video to AVI, then I encode it with tmpgenc and twice the audio synchrosie has been fine, but with other tries it hasn't, so I don't want to try with the whole file just yet until I am sure what I'm doing.
Someone did suggest that I add the audio seperately as tmpgenc doesn't like mp3. I have tried both separately and together with tmpgenc.
Can this be corrected once encoded? I hope s.o. knows the ansa I dont
No, that makes it NTSC.is 23.976 which makes it a SVCD, doesn't it?
No, that in itself doesn't make it a wav, even if VirtualDub sticks a .WAV extension at the end, and adds some wav header. Using Direct Stream, you get the audio in whatever format it is in the AVI, and has to be converted to wav using some AC3/MP3/??? to wav converter.The audio is MPEG Frauenhofer which I convert to wav using Virtualdub Direct Stream
Why? It is in AVI format already.likewise the video to AVI
Bad sync is mainly caused by:- The AVI contains bad frames. There are guides for correcting this, but generally, if you don't have plenty of spare time, it's usually not worth the trouble.
You're trying to encode a NTSC AVI as PAL or vice versa. Dont. Either encode in the same format as the source, or do a frame rate conversion on the source material before encoding.
Just posted this exact message for someone else
Open the avi file in virtualdub, under audio select full processing mode and no compression, then save wav. This will save your audio stream as an uncompressed wav file, so it will be large, approx 10MB/min. Then use this wav file as the audio source in tmpgenc.
If the audio is mp3 with variable bitrate, you need to use full processing mode with no compression. Not direct stream copy. By using direct stream copy you are just stripping the audio out as it is, it needs to be uncompressed.
XviD Encoded videos present distorted bar at the bottom
By deadp0et in forum Video ConversionReplies: 11Last Post: 4th Jul 2015, 09:45 -
How do i calculate the correct bitrate for Xvid codec?
By Ingolf in forum Newbie / General discussionsReplies: 4Last Post: 9th Jan 2009, 10:32 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 19:55 -
Encoded audio is not good - Add better audio?
By NotSoEasy in forum Video ConversionReplies: 2Last Post: 7th Feb 2008, 20:05 -
Can you convert an AVI encoded with Xvid to one with a Divx codec?
By Timfoxx in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 23:53
