    Dec 2003
    Florida, USA
    I have edited this post, now that I found out there is no audio in the DVD+R I created. The instructions below will help you, but you'll probably have no audio. Any sugestions anyone
    Hi everyone, I finally figured out how to create menus and sceen selections.
    DVD-Lab 1.3 rocks!!!! I would like to activate it, but it's $100 . I still have 25 days left for the trail.
    1. First I re-author 3 sections of 3 different movies into 1 with DVDShrink.
    2. Next I backed it up with DVDShrink.
    3. Opened DVD-Lab 1.3, and clicked on the "file browser"
    4. I chose the .vbo files in their sets, and draged them to the bottom window. For example, if you have VTS_01_1, VTS_01_2, and VTS_01_3, you would selct that set of "VTS_01" .vob and drag them at the same time to the bottom window. This will tell DVD-Lab that those 3 files need to be combined. Do the same, for your "VTS_02", VTS_03", etc.
    5. When you drag the files, you will be propted for 3 options. Choose the "demultiplex" option at the very top. Do this for every file group.
    Now you can follow this guide for the rest of the operation. Just continue where it says "Making a movie object".
    http://www.mediachance.com/dvdlab/Help/quick.htm
    No, I don't think I know it all I'm just sharing a little bit of knowlage with some of you that may not know this already. After all that's what forums are for, right
    Lord Pitufo
    A Little Green!!
    TDK Indi 440N
  2. are these keeping menus from the original movies?
    Dec 2003
    Florida, USA
    Nope, these are my own created menu, with the sceene selections.
    Lord Pitufo
    A Little Green!!
    TDK Indi 440N
    Dec 2003
    Florida, USA
    I just found one little problem, there is no audio. I had audio before I created the menus, and I added the audio track as well as the video track when I created each sceene selection. ??? Don't know where it went wrong
    Any ideas anyone
    Lord Pitufo
    A Little Green!!
    TDK Indi 440N
