I installed DVDinfopro and DVDidentifier in XP system. But both did not show my media code at all. Any idea?
Media Information
Disc Regions are 1,2,3,4,5,6,7,8
Media code/Manufacturer ID
Format Type UDF 1.02
Volume Name
Application id Prassi
Implementation id Prassi
Recording Date/Time (mm/dd/yyyy) 12/ 4/2003 21:24:42
Format Capacity 3.10GB(3.33GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed Unknown
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Data area starting sector 30000h
Data area end sector 18CB7Fh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
I know MATRIX media does this.
https://www.videohelp.com/dvdmediaform.php?dvdinfo=1#dvdinfoMany (old) DVD writers can't check the media code on blank DVD+R/RW media so if the media code is not displayed you may need to burn something on the disc first.
I had a similar problem. I had my writer hooked up to a PCI Promise ATA133 IDE card. When hooked to this card using DVD identifier it would not show a media code of any DVD disk either + or -, burnt or blank . When the writer was hooked to the motherboard IDE slot DVD identifier would show the media code.
ffmpeg to windows media server - what does the code look like?
By cyberskoglund in forum Video Streaming DownloadingReplies: 0Last Post: 1st Oct 2010, 15:50 -
PP CS3 Preset/Media Formatting Help -- Banquet show using projector
By scotonn in forum EditingReplies: 3Last Post: 19th Nov 2009, 22:19 -
Same media code, wildly different reviews
By richapple in forum MediaReplies: 5Last Post: 1st Feb 2008, 01:25 -
Real media show discolouring effect
By littlecramp in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 10:50
