I have a double sided movie i want to back up. Each side is about 3.2 gigs. Most movies i back up are at least 7 and a half gigs. Is there anyway i can combine the sides and burn it all onto one disc.
rip both sides of the disk into separate folders on your hd.
open up dvd shrink and click on reauthor.
drag and drop the movie files, you want to combine, under new dvd folder.
uncheck audio and subs you don't need.
click on backup.
show dvdshrink where you want to backup these files and then burn the new files to disk.
try this link for more detailed help.
http://www.doom9.org/index.html?/mpg/dvd2one.htm -
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 16:13 -
Do Any Double Layer Disc Work With Panasonic DMR-EZ48V?
By cbehr91 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 10th Jun 2010, 15:39 -
Burning Double Layer Disc
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2009, 08:22 -
How do I burn double layer disc with Nero 9
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2009, 05:13 -
Double burned disc?
By c5vetman in forum MediaReplies: 3Last Post: 17th Dec 2007, 15:59
