Hello all,
I was wondering if anyone has come across a fix or possibly a work around for this problem?
PROBLEM:
When using DVD-Lab 1.31 ?? (the latest version), I have been unable to change the Title numbers assigned to the items in the project.
EXAMPLE:
With 1 Movie, 1 Slideshow and a few Menus including Chapter Selection when I stop the DVD, resume off, then press Play the Slideshow starts. Ideally if I was able to adjust this the Movie file should be played first.
Other fully authored DVDs I have created have worked correctly? I think it could be that I deleted the first Movie file and replaced it when the Slideshow was already in place, but I havent confirmed this.
Any ideas, as to how I change the Title/Play button back to be the Main Menu or the Movie at least???
Cheers, thanx,
Waz.
if it is what i think it is then it is easy
with the connections window up click on the
second icon to its left ( the plus with a line diagonally down)
then click on the title button and hold the mouse button pulling the arrow to the item you want to play first. is this what you mean?
No sorry that isnt what I needed.
My problem seems a bit more complex than assigning the Title button to the first movie file. The Slideshow has assumed the first Title even when the Title button is assigned to the Movie and or the Root Menu. Naturally I also have the Play first pointing to the Root Menu.
I cant work it out. Could be an IFO edit job but I dopnt understand that as yet...?
Any more ideas fromt he crowd would certainly be welcomed?
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 07:42 -
Menus buttons become assigned to wrong episodes/files
By messiahVx02 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Jan 2008, 02:40 -
DVD Lab - Movie/Title order in connections view
By BeachNut in forum Authoring (DVD)Replies: 5Last Post: 21st Jan 2008, 16:17 -
DVD Lab Project error
By peterhun in forum Authoring (DVD)Replies: 8Last Post: 8th Jan 2008, 19:35 -
Video Type Doesn't Match prob when compiling DVD Lab Pro project
By ulrichburke in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2007, 13:31
