Without getting too long winded...
I have a PAL VHS tape but no PAL deck. Want to digitize footage into machine, edit in Final Cut, dump out as NTSC using either SVCD or DVD. Is this possible by routing an NTSC SVHS deck through an ADVC 100 and firewire or through a DV deck? I know FCP supports PAL but can it take a PAL signal played through a NTSC deck and convert that somehow? ANY suggestions are much appreciated.
Tracking speeds are different (PAL tapes move slower through the machine). Some NTSC VCRs with very wide tracking speed adjustments are able to play PAL tapes in B&W. If your VCR can do that there is some hope. If not, then the video output is just garbage, nothing a system convertor could use.
If it's only one tape just get it converted at a local video store (should be around $10).
The trouble is, A) I don't want to lose a generation and B) I don't want to spend the money AND lose a gen if I don't have to. Looks like I'll have to take it as a loss though...
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
NTSC VHS conversion to PAL DVD where can I buy a combo player
By Wizard81 in forum Capturing and VCRReplies: 10Last Post: 6th Apr 2012, 11:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
