Results 1 to 9 of 9
  1. ive tried 2 times and keep getting this error msg in logtext -
    -->Processing 3 mpeg files.
    ############### New MPEG File ###############
    File: C:\Bile\m00viez\DvD\ICHI1.mpg
    Type: SVCD
    Horizontal Res: 480
    Standard: NTSC
    Audio SampleRate: 44100
    ******** Demultipexing original mpg file
    warning: couldn't find any valid system header. I'm continuing anyway
    (Total size: 788MB, Duration: 00:02:38, Rate(MB/Min): 297.39)
    ******** Resampling audio from 44.1 KHz to 48 KHz
    (Total size: 68MB, Duration: 00:01:24, Rate(MB/Min): 48.47)
    ******** Multipexing elementry streams
    INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    **ERROR: [mplex] File C:\Bile\m00viez\DvD\ICHI1_DVD.mpv unrecogniseable!
    INFO: [mplex] File C:\Bile\m00viez\DvD\ICHI1_DVD.mpa looks like an MPEG Audio stream.
    **ERROR: [mplex] Unrecogniseable file(s)... exiting.
    System.IO.FileNotFoundException: Could not find file "C:\Bile\m00viez\DvD\ICHI1_DVD.mpg".
    File name: "C:\Bile\m00viez\DvD\ICHI1_DVD.mpg"
    at System.IO.__Error.WinIOError(Int32 errorCode, String str)
    at System.IO.FileInfo.get_Length()
    at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
    at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
    is there a work around or am i just tsol ???
  2. Got this problem too with a couple of files. In configurarations I changed the multiplexer from "mpgtx" to "bbdmux" then it was ok. If that does'nt help try changing "mplex" too.
  3. ok i'll give it a shot - way thanx for the options semi !!!
  4. welp, ive tried just 'bout everything on this one...
    guess i'll chalk it up as one of those poorly encoded source filez -
    on to the next svcd...
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    you could try the mpg fix tool but if you have tried most things in the options i would concur with your analysis.
  6. hmmm...
    no, i wasnt aware of a .mpg fix tool chris - where mite that
    be located?
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
  8. doesnt help 1 bit.
    i have this with quite some mpgs lately!, while
    versions before the final version had NO problem with these files!
    I cant reinstall an older version of svcd2dvd ........
    there's no simple fix for this: i tried EVERYthing!
    (mpegfixer, tmpenc, all settings in options etc.etc.etc.)
    I CAN demultiplex but it cant be multiplexed again (not by any other program as well)
    what is different then an older version of svcd2dvd that worked???
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok take the original BIN. rip it with ISOBUSTER. Make a sample for me (using the sample tool) and upload it to:
    ftp://svcd2dvd:Upload@ftp.svcd2dvdmpg.com:7676/tester2
    I will take a look.
    CB
