I have almost 2 TB of video files want to store. Since a 200GB HD is about $100 each, 10 200GB HDs should do the trick. But my PC only have 1 free slot left. So I want to buy something like a external HD enclosure for that purpose, but HD enclosure only allow you to put in 1 HD. Is there anything (enclosure, case...) out there look like a PC minitower but not actually a PC case, which allow you to put in 10 or more HDs and can be connected to your PC by Firewire or USB2?
I don't need anything expensive, or file server. Just a firewire or USB2 device to put in 10 HDs (or maybe some CD/DVD-ROM/drives). I prefer it looks like a minitower. Of course it should come with fan(s) &well ventilated.
Where can I get one?
Results 1 to 12 of 12
Here ya go Try this
http://www.aberdeeninc.com/abcatg/backup-server.htm -
Nice thought, but what do you do when the drive/server fails?
For fixed, or removable, hard drives - this wouldn't be a good idea (in the long run) to store your only copy of video files.
For me, I would prefer an optical disc farm/raid collection rather than that of hard drives.
Just thinking out loud, folks.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
Any external usb device... 256 allowed. perhaps. get a NAS or SAN ..server farm 2terbytes is too much for win/me .. it will take 27mins to boot up and 476 hours to defrag. Also explorer will take 11 mins to show a dir listing
Here is yet another option.
Network attached storage from Linksys. I have one of these myself. I have it running off the router and linked to all 5 machines in the house.
http://www.linksys.com/products/product.asp?grid=35&scid=43&prid=555 -
Thank you all for the suggestions.
RAID or file server is too expensive/complicated for me, and too many individual external HDs all over the place is messy/expensive; I know because already own 2 200GB firewire Maxtor &WD external HDs. So I would rather have 1 large external device to deal.
I guess I am looking for a firewire/USB2 barebone case to put 10 cheap 200GB HDs (maybe 2 CD/DVD-ROM drives) in it.
If there is no such thing, then to all the entrepreneurs out there, please invent it. I will be your first customer.
Who knows, this thing could be a hot item since disk space is never enough when in the video world. Man, who would thought a 60 min .avi file is 12GBs.
just set it up as JBOD (just a bunch of drives) instead of raid ....and add your hard drives or buy a system preconfigured:
FIRE Vue™ RAID Cases With Power Supplies:
1180 2 Drive Case only with 60 watt PS $99.00
5170 4 Drive Case only with 200 watt PS $179.00
1190 8 Drive Case only with 300 watt PS $279.00
2334 2 Drive Rack only with 300 watt PS $199.00
2333 8 Drive Rack only with 300 watt PS $399.00
http://www.granitedigital.com/catalog/pg22a_firewireidehotswapraid_1.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
BJ_M, thanks a lot.
That is exactly what I need.
I will go for the "8 Drive Case only with 300 watt PS" for a cheap $279.
One more question, is it possible to replace the Hot-Swap Tray with a CD/DVD-ROM drive? -
ussually yesOriginally Posted by xcool"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Best way to archive video files?
By preacher238 in forum Video ConversionReplies: 57Last Post: 31st Dec 2012, 12:17 -
Massive video files from my 550D (T2i)
By nateo200 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Aug 2011, 17:45 -
Can HDD Blu-ray DVD player archive DVD and video files?
By coody in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Sep 2010, 12:19 -
Here is a test: Storage of a S**t load of HD video files
By Lesley NZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 25th Apr 2009, 13:26 -
Virtualdub Producing Massive AVI Files
By DaMasteRZ in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 00:37
