I need to do some simple authoring. I recorded a DVD with the Liteon 5001
but I had to split the movie into two titles, one in SP mode and one in EP mode. The result is a DVD that cannot be copied by the usual software: DVD Decrypter, DVDShrink 3.0b5, Clone DVD. They all give an error message when I try to rip in any mode except DVD files. So I can copy the DVD files to my hard drive OK. Now it should be easy to re-author and burn a compliant DVD but how?
TIA
use DVD Shrink
Select open disk, and then choose the dvdfiles that you just rip, and then re-author and backup
this should workIncrease knowledge, increase sorrow. -
DVDShrink won't open the disk, it gives error message, even tho the disk
plays in all standalone players and can be read by Windows. The problem seems to be the .ifo and .bup files on the disk. The "Open Files" menu on DVDSHrink wants an .ifo file so it won't work either.
I have Arcsoft SHowbiz - came with the HP burner. I have not used Showbiz yet but it looks like it will let me import the .vob files and burn them as a menuless DVD. This may be good enough if it works. -
How about using the same technique used for creating a VCD from ripped .VOB files?
Use DVD2AVI to create a .WAV audio track and .d2v frameserving file
Load the above into TMPGenc Plus and select the DVD template. Adjust bitrate/quality to suit and re-encode. This will give you a series of pure MPEG2 files, which you can then use any DVD authoring app to add menus and chapters. -
ktnwin - PATIENCE
BD / DVD Digital Video Quality as compared to Uncompressed RAW video.
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 09:11 -
What format for raw encoding? VOB, AVI or MP4
By Vman94 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2010, 12:00 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
searching camcorder with easy direct copy for video files to PC
By leo315 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Apr 2010, 02:11 -
Easy for someone...why no video with converted youtube files?
By lordstafford69 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 14:00
