I have almost 2 TB of video files want to store. Since a 200GB HD is about $100 each, 10 200GB HDs should do the trick. But my PC only have 1 free slot left. So I want to buy something like a external HD enclosure for that purpose, but HD enclosure only allow you to put in 1 HD. Is there anything (enclosure, case...) out there look like a PC minitower but not actually a PC case, which allow you to put in 10 or more HDs and can be connected to your PC by Firewire or USB2?![]()
Closed Thread
Results 1 to 13 of 13
RAID - Redundant Array of Independent Disks
You can get many drives look like one drive (eg 10 200GB drives will look like a 2TB drive) w/ RAID.
I don't know if a HD "tower" exists...
You could as stated above with the PCI card but it will get pretty messy with 10 drives. Instead, you can get 300GB drives (maxtor has some) and have less clutter.
By 'archive' you want to store them, so they will not be accessed frequently?
"I have almost 2 TB of video files want to store"
Got a DVD Writer ... ??? and a few 100 discsIt appears that the CPU was operating so fast that it began to execute instructions before they arrived. This execution of future instructions created a small tear in space-time itself through which part of the cpu passed into a parallel universe
Originally Posted by 808smokey
No need to double post:
https://www.videohelp.com/forum/viewtopic.php?t=199593
Best way to archive video files?
By preacher238 in forum Video ConversionReplies: 57Last Post: 31st Dec 2012, 11:17 -
Massive video files from my 550D (T2i)
By nateo200 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Aug 2011, 16:45 -
Can HDD Blu-ray DVD player archive DVD and video files?
By coody in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Sep 2010, 11:19 -
Here is a test: Storage of a S**t load of HD video files
By Lesley NZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 25th Apr 2009, 12:26 -
Virtualdub Producing Massive AVI Files
By DaMasteRZ in forum Video ConversionReplies: 5Last Post: 23rd Aug 2008, 23:37
