Does anyone know how to convert dvd mpeg to vob files......
anything helps...thanks....
use a program called "tmpgenc dvd author" its real easy just go through the steps and save to a folder once done open "nero" burning rom and drag and drop the new vobs into the "video_ts" and burn.
works great for me -
@ rstoneba,Originally Posted by ricky1756
Check out the "DVDR" link in blue, top left of the page, for DVD specs. If you're not sure about your file, GSpot provides a lot of info. Also, if you're using TMPGEnc to encode to mpeg2, I found this guide:
http://dvd-hq.info/Compression.html
...VERY useful and informative for the settings.
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
When you say DVD mpeg are you talking about MPEG 2 files? If so they are already compliant, just change the extention from .m2v to .vob.Originally Posted by rstoneba"Can You Dig It!"
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
Burning DVD's after converting to .vob files
By Joyful Noise in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2010, 23:37 -
Converting DVD(.vob)files to ONE file
By LouieLand in forum Video ConversionReplies: 14Last Post: 10th Feb 2010, 02:58 -
Converting .mpeg files to watch on DVD?
By prankstare in forum Video ConversionReplies: 7Last Post: 8th Jun 2008, 20:41 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
