I have a problem in DVDLab when I shall Compile my DVD.
When I press "Start" it starts as nothing is wrong, but just before it's halfway, it stops and I get a message:
"Microsoft Visual C++ Runtime Libary
Runtime Error!
Program: C:\Programfiler\DVDlab\compile.aux
abnormal program termination"
What does this mean? Is there a bug in the program or is there another software of mine that has a bug?
Im using a computer with Windows XP Home edition and I am using version 1.1 of DVDLab to create a film set in PAL.
Does anyone know what ho can help.
Hi Hendrik,
i had the same problem.
the solution if i remember rightly is to change the audio format.
i now demultiplex the mpeg and then change the audio format to
i will check at home tonight exactly what settings i use
Problem with subtitles off by default in DVDlab-pro
By blajko in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2010, 20:21 -
Subtitle problem with DVDLab Pro
By carlmart in forum Authoring (DVD)Replies: 3Last Post: 21st Nov 2008, 10:18 -
First Play problem in DVDLab PRO
By grzegorz in forum Authoring (DVD)Replies: 5Last Post: 11th Apr 2008, 05:43 -
problem with dvdlab pro2
By postie1392 in forum Newbie / General discussionsReplies: 10Last Post: 27th Sep 2007, 07:00 -
Problem with DVDlab and 16:9 motion menus
By sektionschef in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 06:11
