  1. Further to my previous post (to which I received no replies)
    I have a VCD in BIN / CUE format.
    I have burned it to a CDR and played it successfully on my DVD player with picture and audio perfect.
    When I use SVCD2DVD to convert it, I get perfect audio, but NO VIDEO except (occasionally) a small area of coloured boxes in the top left corner.
    I am using the latest version. I had no problems with this prior to the new registration system, and therefore the latest version.
    I have also tried ripping the MPG from the BIN file using ISOBUSTER, and the resulting MPG file plays fine in media player. When I use this file for my source in SVCD2DVD it still gives me the same result - NO VIDEO.
    So it is not the ripping stage that is the problem.
    It is not my DVD media either, because sometimes one title on a DVD works, yet the other has no video.
    C'mon ChrissyBoy, I paid my money, gimme some help please!
    BTW Here is my log file:
    Starting SVCD2DVD: v1.51.2.0
    Begin time: 18:14:16
    Analysing File: C:\Documents and Settings\Monster\Desktop\New Folder\la.mpg
    ++ WARN: packet length beyond buffer (pos = 18 + size = 2030 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
    ++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
    -->Processing 1 mpeg files.
    ############### New MPEG File ###############
    Type: VCD
    Horizontal Res: 352
    Standard: NTSC
    Audio SampleRate: 44100
    ******** Demultipexing original mpg file
    (Total size: 771MB, Duration: 00:02:29, Rate(MB/Min): 309.04)
    ******** Resampling audio from 44.1 KHz to 48 KHz
    (Total size: 109MB, Duration: 00:01:39, Rate(MB/Min): 65.65)
    ******** Multipexing elementry streams
    INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    INFO: [???] File C:\Documents and Settings\Monster\Desktop\New Folder\la_DVD.mpv looks like an MPEG Video stream.
    INFO: [???] File C:\Documents and Settings\Monster\Desktop\New Folder\la_DVD.mpa looks like an MPEG Audio stream.
    INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [???] Found 1 audio streams and 1 video streams
    INFO: [???] Selecting dvdauthor DVD output profile
    INFO: [???] Multiplexing video program stream!
    INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\Monster\Desktop\New Folder\la_DVD.mpv)
    INFO: [???] VIDEO STREAM: e0
    INFO: [???] Frame width : 352
    INFO: [???] Frame height : 240
    INFO: [???] Aspect ratio : forbidden
    INFO: [???] Picture rate : 29.970 frames/sec
    INFO: [???] Bit rate : 1150000 bits/sec
    INFO: [???] Vbv buffer size : 49152 bytes
    INFO: [???] CSPF : 0
    INFO: [???] Scanning for header info: Audio stream c0 (C:\Documents and Settings\Monster\Desktop\New Folder\la_DVD.mpa)
    INFO: [???] MPEG AUDIO STREAM: c0
    INFO: [???] Audio version : 1.0
    INFO: [???] Layer : 2
    INFO: [???] CRC checksums : no
    INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
    INFO: [???] Frequency : 48000 Hz
    INFO: [???] Mode : 0 stereo
    INFO: [???] Mode extension : 0
    INFO: [???] Copyright bit : 0 no copyright
    INFO: [???] Original/Copy : 1 original
    INFO: [???] Emphasis : 0 none
    INFO: [???] SYSTEMS/PROGRAM stream:
    INFO: [???] rough-guess multiplexed stream data rate : 1401296
    INFO: [???] target data-rate specified : 10080000
    INFO: [???] Setting specified specified data rate: 10080000
    INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
    INFO: [???] New sequence commences...
    INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
    INFO: [???] Scanned to end AU 122532
    INFO: [???] STREAM e0 completed @ frame 122532.
    ++ WARN: [???] Discarding incomplete final frame MPEG audio stream c0!
    INFO: [???] STREAM c0 completed @ frame 170353.
    INFO: [???] Multiplex completion at SCR=367972205.
    INFO: [???] Video e0: buf= 229811 frame=122532 sector=00293112
    INFO: [???] Audio c0: buf= 2080 frame=170353 sector=00056673
    INFO: [???] VIDEO_STATISTICS: e0
    INFO: [???] Video Stream length: 587724307 bytes
    INFO: [???] Sequence headers: 1
    INFO: [???] Sequence ends : 1
    INFO: [???] No. Pictures : 122532
    INFO: [???] No. Groups : 6955
    INFO: [???] No. I Frames : 6955 avg. size 15200 bytes
    INFO: [???] No. P Frames : 34195 avg. size 6373 bytes
    INFO: [???] No. B Frames : 81383 avg. size 3244 bytes
    INFO: [???] Average bit-rate : 1150000 bits/sec
    INFO: [???] Peak bit-rate : 1596000 bits/sec
    INFO: [???] BUFFERING min 63937 Buf max 135651
    INFO: [???] AUDIO_STATISTICS: c0
    INFO: [???] Audio stream length 114477892 bytes.
    INFO: [???] Syncwords : 170355
    INFO: [???] Frames : 170355 padded
    INFO: [???] Frames : 0 unpadded
    INFO: [???] BUFFERING min 15 Buf max 683
    INFO: [???] MUX STATUS: no under-runs detected.
    (Total size: 696MB, Duration: 00:01:40, Rate(MB/Min): 415.59)
    Analysing File: C:\Documents and Settings\Monster\Desktop\New Folder\la_DVD.mpg
    ++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
    ++ WARN: mpeg stream contained no scan information (user) data
    ++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
    ******** Creating DVD Folders...
    Creating VTS #1
    SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    -->: DVDFolders creating VTS
    -->: VTS 01
    STAT: Processing C:\Documents and Settings\Monster\Desktop\New Folder\la_DVD.mpg...
    -->: DVDFolders creating table of contents
    scanning C:\Documents and Settings\Monster\Desktop\New Folder\VIDEO_TS/VTS_01_0.IFO
    (Total size: 696MB, Duration: 00:02:01, Rate(MB/Min): 344.46)
    ============ Complete ============
    ============ Duration: 00:07:53
  2. Maybe a strange suggestion but can you try a VCD you already did once with the new version? Just so we can determent if it is the new version or just the one VCD that is giving problems.
    Greatings,
    Yf
