  1. I have an mpg file that I demux using the mpg tools in TMPGenc.
    After it is demuxed there are 2 files a video m1v and an audio mp2. I want to do some editing to the audio file so I was able to open it in one of my editors but had to convert it to a wav to be able to use the audio software that I wanted to edit with.
    So now I have a wav file that I assume needs to go back to an mp2 file so using TMPGenc I can multiplex it back with the video as TMPG doesn't see a wav file, but neither of my editors have this option.
    How do I do this?
    Apr 2002
    The State of Frustration
    You can use the TMPGEnc main program screen to do the remultiplex. Just use the m1v as video input, and the wave as audio input. Select the template, output file name, and press Start.
    Hello.
  3. Thanks that worked fine.
