Hi,
I am experimenting with DVD Shrink 3.1.2, using Full Disk mode, mix compressions (max compression on menus, still pictures on extras, minimum compression on the main movie). The test movie was only compressed slightly (less than 6%). Is it possible that DVD Shrink may not "catch" any possible bad sectors on the original DVD? The result main movie had a few places that locked up during playback, even though that was not indicated during Deep Analysis. Or is it some other factors that would cause this to happen?
Thanks in advance...
Spiffy
If you didn't use deep analysis, it's possible it missed something. It can also be a marginal burn and your player missed it. Run the disk through DVDInfo Pro and check it for errors first. Then try viewing that scen on your PC and anotehr player.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Fake malware popup creators caught
By redwudz in forum Off topicReplies: 4Last Post: 30th Jun 2011, 20:57 -
how do i remove an angle lock from a dvd
By animalia in forum DVD RippingReplies: 1Last Post: 10th Jan 2010, 03:11 -
Ripbot lock-size @ 8150 too big for DVD+R
By Z.Sath in forum Blu-ray RippingReplies: 14Last Post: 3rd Jun 2009, 06:44 -
Problem with blue light caught on video
By maevek1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 8th Apr 2008, 05:02 -
Gettin caught
By fookju in forum Off topicReplies: 1Last Post: 5th Jun 2007, 06:01
