Hi!
I just upgrade from Premiere 6.5 to Pro and I am having problems on trying to export just the work area of my sequence. Can anyobody give me some tips?
Presumably you are selecting work area when you export? I did recently did the same upgrade (well trial upgrade for the moment) and found that work area was defaulting to the same as the whole sequence. Just double clicking on the unit ruler on the timeline will bring the work area down to the view of the timeline and you can grag the sliders in or out from either side.
Then as per 6.5 just select work area for your export rather than sequence (6.5 option was either whole project or work area).
Slight change of topic but how are you finding the audio output since the upgrade? I found the audio (for camcorder stuff), when using either MPEG audio or AC3, that it was distorting and I had to turn the whole audio down a couple of DBs. I never had this problem with 6.5, in fact with 6.5 I could increase the DBs a little when required with no distortion. -
When you export your video and the screen comes up to save as, drop your box that says timeline to working area. That should do it.
[premiere pro] i can't work in 480p (854x480) resolution, how to do this ?
By Michael REMY in forum EditingReplies: 14Last Post: 1st Jan 2016, 22:55 -
Plural Eyes with Premiere Pro? Does it work?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2011, 12:36 -
Lost the movie + audio area in premiere cs3
By eliqush in forum EditingReplies: 0Last Post: 25th Jul 2011, 13:26 -
DVD Studio Pro 4 - Subtitle area width?
By Geiger9 in forum MacReplies: 1Last Post: 6th Feb 2010, 21:44 -
Will MPG4 Work With Premiere Pro 2?
By HarveyCee in forum EditingReplies: 0Last Post: 16th Feb 2009, 12:30
