I'm looking for a simple program that will let me cut half off a .mpg. I tried using Nero's cutting program but it says the file wont run correctly. I want to cut about a half hour off the end.
I would suggest the Merge & Cut function from TMPGEnc Plus, as it does not re-encode, I'm told. Select File--MPEG Tools...-->Merge & Cut.
Hello.
Missing audio in mpg files from Sony Camcorder in Final Cut and Quicktime
By Benhermies in forum MacReplies: 3Last Post: 2nd Feb 2011, 22:13 -
Final Cut Pro imports .MPG's with no audio.
By Benhermies in forum MacReplies: 2Last Post: 20th Sep 2009, 16:09 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57 -
How can I cut out an image from a mpg file? Just one frame
By szalaikornel in forum Video ConversionReplies: 4Last Post: 28th Jan 2009, 10:59 -
cant trim/cut mpg in QT-pro
By Kevlin in forum MacReplies: 3Last Post: 17th Aug 2008, 13:25
