    Nov 2003
    Using Dvd Decrypter, Dvd2One and to burn RecordNow Max.
    My first dvd went fine but lately an error comes up using Re no max
    Sometimes it works and sometimes its not.
    During the burn it suddenly stops and the error say:
    Data Job Untiled1 Terminated With Errors
    Error -9 at sector 1029184
    So new to this and could really use some help..
    ( A scandinavian blonde)
    vapea
    Dec 2003
    Florida, USA
    What brand of Meda do you use?
    Most of the time, erros in the recording process are because of bad/cheap media (ie. Princo).
    Adam
    DVD Decrypter>DVDShrink>CopyToDVD
  3. This just has to be media.
    I use RecordNow and have a spindel of K.... DVD - R that will not
    record. I get the same error as you.
    Try the best media you get get.
    I use HP dvd+r, TDK and ive had good results with compusa dvd-r.
    I have a Sony 510.
  4. 1. Get the latest firmware for your burner
    2. Update RecordNow pxEngine
    http://support.sonic.com/dwnld/engine_download.asp?type=desktop
    Nov 2003
    Im using Traxdata.
    Perhaps i should try something else then ?
    Have a Hp burner so perhaps i should use those dvd..
    But is it totaly safe to use a dvd thats "famous", i mean it could
    fail anyway ?
    vapea
