Who has a LiteOn DVD +- writer and knows what the best brand of DVD+r is to write on?
I have problems with playing in my Phillips 634, the movie freezes sometimes.
I used Princo and Emtec without any succes of good quality movies.
Someone knows with brand is good to work with?
Results 1 to 12 of 12
Ritek, Taiyo Yuden, Verbatim, and BeAlls IMO.
Go to >>> www.rima.comAdam
DVD Decrypter>DVDShrink>CopyToDVD -
I wanna know from people who has a LiteOn DVD writer wat brand they use. And what problems they have with it.
Its not soley dependant on your burner. It has alot to do with the media. In this case you want good brand name stuff. And what you are going to find is that probalby 85-95% of the people here, whether +R, -R, Pioneers, Sonys, LiteOns....doesnt matter, they use Riteks from my findings. They make great stuff. Also, your burner burns digital data and it matters on what media you use. Sometimes it is the DVD players fault whether it plays right or not because it isnt -R or +R compatible. So please take that into consideration.
Adam
I second Adam's recommendations and thinking.
Some people have good luck with Princo and Emtec. Some don't. Try a forum search with your DVD burner's model number and the word 'media' and see what comes up. -
Lately Ive been using :
DVD-R by Fujifilm, Memorex, or TDK
DVD+R by TDK
(mainly purchased at Target or Costco)
Havent had one bad burn using DVDdecrypter to rip, DVDshrink to reencode, and Nero to burn on my LiteOn LDW 451S... -
I have Lite on 411S (+R and -R)
I use Sony,Pengo and Melody
no problem with one of them.....
Problems with princo, but I read You can fix that updating the Firmware
Good look -
I would believe that Ricoh would work, it's what came with the burner, look to fuji and memorex.
Blah, blah, blah -
I'm pretty much a TDK mark. The burner I bought was a TDK and the disc came with it. Not only that but if I buy them at Target they come with the boxes
No problems with them so far.
"Can You Dig It!" -
Verbatim
What We Do In Life, Echoes In Eternity.... -
I have a liteon 401s and no probs with any media I have used so far. Fuji, Ritek, CMC, Optodisk, Rioch and TDK. All burns and plays well. Very happy with my liteon so far.
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 22:29 -
HD DVD Combo Discs ???
By ofield1 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2008, 06:54 -
HELP - Can`t erase 10 dvd rw discs
By LOWTECH in forum DVD RippingReplies: 6Last Post: 13th Aug 2007, 14:28 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 06:03
