    Dec 2003
    united kingdom
    Hi,
    1. used dvd2one to rip a movie, i'd opened dvddecrypter 1st to see how big the *movie only* was, and it was just 4.9gb (identity). so decided to rip with dvd2one, using variable bitrate, the resulting file was just 3.2gb, wierd..?
    i thought it would just ever so slightly compress the file so it would just fit the disc.
    2. when i use dvd2one, movie only, sometimes i can select more than just 1 file which is the movie lenght (identity again), whats all that about then..?
    thanks in advance for any help.
    Oct 2003
    Central Texas, USA
    1) You cannot rip with DVD2One. It is a compression software, not a ripping software. You use it AFTER ripping with DVD Decrypter. Was this DVD you *ripped* with it unencrypted?
    2) The rest of your question makes no sense since you can't rip with DVD2One.
  3. i would assume you're using anydvd when you say rip with dvd2one. anyway, dvd decrypter displays movie only size with all soundtracks. i will assume you are dropping all but one english track and therefore greatly reducing the size. so nothing is being compressed. when you see two files of equal length in the video selection, one is 4:3, and the other 16:9. if i made no sense you need to read more tutorials.
    Dec 2003
    united kingdom
    yes, thats right, i use anydvd, thanks for your help.....
  5. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Try these
    1. Dvd Decrypter
    2. Dvd2One (fits files to dvd)
    3. Copytodvd (burns)
    What We Do In Life, Echoes In Eternity....
    Nov 2003
    I DON'T KNOW
    If you have Anydvd you can rip a dvd with DVD2ONE[/quote]
