HI,
I got the following camcorder: MEDION MD 9014 And I would like to transfer the video (in any format you wish) to my Pc. Didn't found any guides without using a digital cam/dv recorder for doing the job, I got a ATI RADEO 9800 XT video card what should do the job.. only need a program that does it..
As you may read I'm a newbie with capturing but if any1 can give me the name of a program I think Ill sort it out..
So the question is, is there ANY solution capturing a hi8 videotape to your pc without using/buying/borrowing external hardware??
Thx in advance!
Originally Posted by chillyah
HI,
Thanks for your reaction, ok.. I made some advances I hope:
Installed Multimedia Center 8.8 for ati and newest drivers..
Now I get the sound directly through my speakers..
But if I select CAPTURE AVI in virtual dub I don't get anything yet..
So if you could explain, or gimme a tutorial for capturing analog hi8 with virtual dub or any other program, Id appreciate that very much
thx -
Allright, I got it sorted out now.. Finally get a streaming now, but in BLACK AND WHITE?? And the TFT screen on my camera is in color..
So what settings are recommenced in Virtual Dub to stream the file correctly...??? -
To make virtualdub capture work with my ATI AIW Radeon I have to first start the ATI TV application in MMC and then close it to initialize my card correctly and then I can start virtualdub and capture with colour.
Ronny -
Allright I see, aint got no time to figure it out now but I think that ll do the job..
Anyway, here's another problem... If I try to capture it with FLYDS, I do get color.. But no bloody sound, but I do hear the sound through my speakers when I just play it in FLYDS/Virtual dub..
After it's captured the sound is gone.. Is this an issue with my soundcard, do I get additional capture drivers or so???
Should be the last problem to solve, your help is appriciatedThx
Best Sony Digital8 Camera to convert 8mm/Hi8 to PC?
By Optical in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 7th Oct 2017, 11:34 -
Should I capture VCR, 8mm and Hi8 tapes to MPEG2 or MPEG4?
By dorenhagen in forum Capturing and VCRReplies: 18Last Post: 25th Jan 2011, 22:00 -
I have about 60 Hi8 and regular 8mm camcorder tapes that I can't get toplay
By Chris McDowell in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Jun 2010, 18:12 -
Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVD
By scotty123 in forum Video ConversionReplies: 0Last Post: 9th Oct 2009, 12:49 -
By scotty123 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2009, 00:34
