I just downloaded a MTV Clip and want to burn it an VCD. The problem is that there is a small commercial part in it at the beginning. I want to cut this out. I found a program VirtualDub, but this program can only save it as *.avi. Do someone know a program which can save the MTV Clip (which is a MPEG) directly into MPEG after cutting out the commercial part?
I already tried TMPGEnc too, but I couldn't find a way to do it.
<font size=-1>[ This Message was edited by: Fung on 2001-10-17 14:42:36 ]</font>
You can try MPEG1VCR or MyFlix. These won't reencode, so the quality will stay the same.
For TMPGEnc, it's under the File|MPEG Tools menu, then select the Merge & Cut tab.
/\/\ars /\/\ayhem
How do I cut out a part from a MP4 file
By Mickie in forum EditingReplies: 8Last Post: 11th Aug 2011, 08:01 -
Cut a part from a MKV file
By H2SO4JB in forum Video ConversionReplies: 0Last Post: 17th Oct 2010, 09:15 -
Can't cut part with vdubmod?
By kkiller23 in forum EditingReplies: 1Last Post: 19th Sep 2010, 07:15 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
How to cut out a part from DVD?
By DjuKa in forum EditingReplies: 8Last Post: 23rd Oct 2008, 11:03
