Hi,
I've read the SVCD->DVD tut and that does what it's meant to do fine, however what I want is to be able to convert from the SVCD format and place on the DVD in a format that will play on any DVD player.
I resampled the audio to 48KHz and whacked it through nero which re-encodes it or something. The result are a set of VOB files etc... that play on DVD players but with A/V synch problems. Anyone know how to sort this?
I've got the same problem...
I tried splitting up A/V and converting audio to 48KHz then using TMPGEnc to make a new file (mpg)
Then I tried to burn the new mpg-file in Nero Vision Express 2 (NVE2), and I still have A/V sync problem.
I belive NVE2 have problems with A/V sync in general....
Haven't found any solution.......000....000....
Angelot :-D -
How about svcd2mpeg? Only tried it with one SVCD (2 disc set), authored with DVDLab - Perfect!
/Mats
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
Encoding issues
By gdub in forum ffmpegX general discussionReplies: 3Last Post: 26th Feb 2009, 11:59 -
Mpeg Streamclip synch issues
By filter5 in forum Video ConversionReplies: 1Last Post: 11th Aug 2008, 21:41 -
Audio synch issues when converting to XviD or DivX
By baduncan in forum Video ConversionReplies: 3Last Post: 15th Dec 2007, 13:25 -
Audio synch issues with Youtube uploads
By fusiblelinks in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 21:34
