Does anyone encounter this problem after the upgrade to newer version. SVCD2DVD v1.51.2 doesn't start. It just flash with hour glass and disappeared.
I even reinstalled the windows xp, and also reinstalled SVCD2DVD but the registration page never pop up again like it should for the first time installation. :evil:
PC P4 2.8HT
512M
Winxp pro (SP1)
NetFrame 1.1
SVCD2DVD v1.51.2 (got this from Chris through email)
Any help will be appreciate.
Results 1 to 16 of 16
What is the date on the MSI file?
I don't know how to tell built date on this msi because its a exe file attached with the email. Once i save it to my computer, the date will modified to my computer's current date. The email I received on JAN 12 6am.
Here is the revision number of the MSI:
revision number {22DE535A-02DF-47E5-B5AC-BB0CA927D966}
Thanks -
ok do you want to drop me an email?
i have got the same problem. the program worked fine for a couple of times and then it just displays the start screen screen with the stack of discs, this then disappears and nothing happens.
i have tried re-installing and selecting 'repair' but this doesn't seem to do the trick.
I recieved email from yourself on 15/1/04.
is there any other information you need????
would be very grateful if you could help me out on this one
cheers. -
Drop me an email 309.
Im having the same problem, It worked perfect on WIN98SE, also worked fine on WINXP Pro before I upgraded to SP1. Please let me know if any info is needed from me.....Originally Posted by 309
don't worry about it . chrissy boy will sort you out.
he did with me and it has worked fine since.
all i had to do was re-register :oops:
he doesn't know what caused it though, although with the amount of messages with the same problem i don't think it can be a user error -
[T]H3[k]R8v0n3 - drop me an email please & I'll try to sort this out for you.
There may have been a change to your system. If you double click on the SVCD2DVD demo.exe file in the SVCD2DVD folder you can redo the registration process. This should solve the problem.
afoken, drop me an email & we'll take a look.
Launch program at start up
By CSULB71 in forum ComputerReplies: 4Last Post: 21st Jan 2012, 12:12 -
Is SVCD2DVD the program for my HD files?
By rimam in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 20th Mar 2008, 15:12 -
SVCD2DVD won't launch on my XP laptop
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Oct 2007, 10:29 -
moduleC:\program files\badgerit\svcd2dvd v2.5\code-lock.ocx failed to regis
By itsjimmyb in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 30th Jul 2007, 09:41 -
SVCD2DVD won't launch after latest Windows Update of MS .net framework
By starkraving in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Jul 2007, 04:42
