I've got an Fujitsu Siemens Scaleo 1,7 Ghz with 256 MB RAM and onboard soundcard (64MB) and onboard videocard (SiS)....
Is this enough when ripping/converting/burning DVD-video?
Angelot?
...000....000....
Angelot :-D -
Yes, it is, although your DVD-rom speed will determine the ripping time, your processor/RAM will determine the conversion time and your burner will determine the burning time.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I've got a fast DVD-rom - ripping takes only 10-20 minutes....
Converting vob's to avi with AutoGK takes 7 (!) hours. With 1,7 Ghz I belive that's fast enough, but it seems that I need more RAM (256 is not enough). Or is 7 hours normal?
The transcoding process takes over 4 hours in Nero, and I belive this is due to the same problem?
I've got a NEC 1100-A 2.4x and the burning process takes only 10-15 minutes....
Conclusion: I need more RAM?...000....000....
Angelot :-D -
More ram will give you a little overall "boost", I am pretty sure you got a Celeron cpu, wich as far as I know don't give the same performance as what Pentium and Athlon does.
I used to encode divx on my old siemens scaleo 500mHz (Celeron), It took hours and hours, but I did get to the destination. Most of the Lefdal\Elkjøp computers costs more than they are worth
After my ram upgrade from 256 to 768 I got much faster results when encoding with Cinema Craft Encoder.
(PS: Fint med litt Nordmenn her
10110101100111012011 <- The bug Bill doesn't talk about. -
i agree with ronnylov: no need to bother converting when the data is alreay in the correct format!
Music was my first love, and it will be my last
3gp videos from mobile run too fast in computer
By DeltaTango in forum Video ConversionReplies: 2Last Post: 1st Oct 2010, 05:17 -
Fast encoding on a slow computer
By si4h in forum Newbie / General discussionsReplies: 11Last Post: 5th Aug 2010, 11:09 -
Fast Computer Extremly long time Encoding
By doz in forum Video ConversionReplies: 5Last Post: 24th Apr 2008, 13:45 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 19:49 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
Angelot?
