  1. If I use SmartRipper in "Movie Only" mode, the files that are generated on my C drive can be read successfully by PowerDVD .. the movies plays perfectly.
    But .... if I then try to compress the movie using DVD Shrink it complains about missing files.
    If the movie doesn't need to be shrunk, I can't use Nero to burn it due to the same missing files.
    Why's that ?
    If I use SmartRipper in Full mode, there doesn't seem to be a way in DVDShrink to ignore all the extra etc. I can compress them to "Still Only" but I can't see a way of not writing them at all
    Help appreciated !
    Dec 2003
    Florida, USA
    Originally Posted by wulf109
    DVD2ONE upto version 1.30 will trancode from ifo/movie only files to a directory you select on your HD.
    IFOEDIT's create ifo files requires that the vob files be named VTS_01_1.VOB,etc,if you name VTS_02_1.VOB you will get an empty directory.
    If that doesnt work for you try to rip the entire Disc with DVD Decrypter and use the Re-Author option in DVDShrink. Any problems doing that just ask.
    Adam
    DVD Decrypter>DVDShrink>CopyToDVD
