Hi all
New to all this so I thought I would ask a question. How long should it take to back up a DVD movie?
FYI I am using Nero 6.3.0.0, my O/S is WIN XP PRO.
Initially when I got the writer I was using USB 1.1 and burns were taking 120 - 150 minutes, so I upgraded to USB 2 and now 1 full length film takes between 45 and 65 minutes.
My writer (Freecom Classic external DVD+/-R aka NEC 1300A?) claims to write at upto 4x and the best times I have achieved have been with a 4x disc.
Does this seem about right?
Cheers
James
Results 1 to 16 of 16
That is of course assuming a full disc.Originally Posted by tompika
USB does not have the transfer rate of EIDE, so that would perhaps explain your slower burn speeds. -
I'm using Nero Vision Express 2 and burn a full DVD-video on 4-5 hours!
The actual burning is done in 10-15 minutes - it's the transcoding that takes so much time....
Am I doing something wrong or is this normal?
Angelot
...000....000....
Angelot :-D -
Thanks for all your replies!
I just tested my USB2 connection, and thats working fine but a full disc is still taking between 45 & 60 mins!
I guess there is over 160 mins of material that I am backing up, so does that mean I am working at about 2.4 x ?
Also, looking at the media I am using they don't say that they burn at 4x (in fact one says it's only 1x but it still takes about an hour!). Surely these figures make a difference, but I am not sure what that difference means!
Anyway, thanks again - any further guidance would be appreciated!
James -
James youre NOT burning at 2.4x
Burning a full DVD
1x takes about an hour
2x takes 28-30 min
2.4x takes 22-24 min
4x takes 14-15 min -
Thanks Tompika
I guess I need to buy some 4x media and see if that makes a difference!
Can I ask a thick question though, if a film is over 2 hours, and burning it takes an hour, why wouldn't that be a 2x burn? Does the 1 x refer to something other than duration?
Cheers! -
Ok I think I get ya!
1x (or whatever) refers to data transfer rates as opposed to "real time".
Cheers.... -
try these
1. Dvd Decrypter (5 mins aprox)
2. Dvd2One (15-20 aprox)
3. Copytodvd (10 mins) 4xWhat We Do In Life, Echoes In Eternity.... -
Well since using the Memorex 4x dvd+r's it is only taking me around 10 mins, maybe 12 mins max
Either that or its not a full DVD
true
Ulead Video Studio 11+ DVD Burning takes very long time
By chrayf in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2012, 15:43 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 03:12 -
Burning as Divx- burn time-why so long-alternates?
By Rik62 in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2008, 18:19 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 20:08 -
Long time burning and skipping problems
By championjosh in forum DVD & Blu-ray WritersReplies: 8Last Post: 16th Feb 2008, 02:11
