Hello!
I have a question about bitrates on a AVI to MPEG2 to conversion. When I check the bitrate in VirtualDUB, it says that it is 995 BPS in the AVI. When converting to MPEG can I lower the bitrate setting in TMPEG to around the same amount without losing quality?
Thanks for your time,
Eric
No. The AVi bit rate and mpeg bit rate are not related at all. The higher bit rate you use when encoding, the closer to the source material quality you'll get (but never really 100%).
/Mats -
Hi ewharding2000,
I found this guide:
http://dvd-hq.info/Compression.html
...really useful for my TMPGEnc settings. Explains them in good detail.
Hope that helps.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
As your avi is almost certainly some form of mpeg-4 variant (divx, xvid etc), which uses much higher compression than mpeg-2, you in fact need to signficantly increase the bitrate to even get close to the quality of the source. You also have to take into account any resizing being done. If the mpeg-2 is higher res than the source avi (say 720 * 480 mpeg for DVD Vs 640*480 4:23 avi), you need to increase the bitrate a corresponding ammount to compensate for the extra data required to represent the extra pixels.
From a good quality divx (no more than 1 hour per CD), quadruple the bitrate when going to DVD as a starting point.
Best way to reencode mpeg2 to lower bitrate
By justcurious in forum Video ConversionReplies: 3Last Post: 22nd Nov 2011, 17:05 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
mpeg2 bitrate conversion
By sandiegoguy in forum MacReplies: 6Last Post: 16th Aug 2009, 03:40 -
Bitrate question for Avi to Wmv conversion w/ Windows Media Encoder
By Gonz0ne in forum Video ConversionReplies: 5Last Post: 6th Jan 2008, 08:19
