Can cce be used on pentium 2 400mhz?
Results 1 to 12 of 12
tried the stand alone - no success
Tried the prmier plugin but keep getting :
"Frame 1/1 is not supported"
anybody have a clue? -
I've used 2.5 standalone on p2-450 & 2k, but i frameserver (not avisynth beta) to the 2.5
i am trying this with no success
copied the prmier plugin to flask and changed its name
managed to get it to work but the coding doesn't work..i get an error..:
cce encoding failed:exception occured at frm cap video buffer sync
help -
o.k. a gave up
Trying to see if cce would work on a pentium II 400
So i made an avi and tried to encode it using cce standalone - again no success...keep getting the following error:
CCTSP executed an invalid instruction in
module CCTSP.EXE at 0177:0047b02c.
Etc
Help -
did u copy the frameserve dll in the \system dir??
i'll verify on my work machine tomorrow and let u know. -
wht does that have to do with it
if i use only the standalone with avi (no frame serving)
it should work no? -
All the CPUs:
Intel(R) XeonTM processor
Intel(R) Pentium(R) 4 processor
Intel(R) Pentium(R) III processor (including mobile and XeonTM processor)
Intel(R) CeleronTM processor (533A MHz or greater)
Intel(R) Mobile CeleronTM processor (400A/450/500 MHz or greater)
AMD AthlonTM MP processor
Mobile AMD AthlonTM 4 processor
AMD AthlonTM processor
AMD DuronTM processor (including mobile processor)
Is a 2.8 Pentium 4 w/HT able to playback HD?
By GLE3 in forum ComputerReplies: 2Last Post: 25th Mar 2009, 11:36 -
Going from amd 9850 to pentium 9550
By johns0 in forum ComputerReplies: 1Last Post: 24th Sep 2008, 00:30 -
Pentium P4 SL7E2 = Northwood or Prescot ???
By blinky88 in forum ComputerReplies: 6Last Post: 4th Aug 2008, 15:26 -
Performace...Pentium D to Core 2 Duo
By ron spencer in forum ComputerReplies: 14Last Post: 31st Mar 2008, 18:42 -
3.4 Pentium 4 or 935 Pentium D?
By DarrellS in forum ComputerReplies: 6Last Post: 12th Jan 2008, 00:58
