how do i get .avi files onto a dvdr disk. it doesnt matter if there are no chapters but what program would i use to get my .avi files onto a dvdr disc? with a menu?
thanx
Results 1 to 15 of 15
-=Turbo=-
everytime i add the .avi file to convert it to dvd in TMPGEnc it says:
"filename" cannot open, or unsupported..
its an avi file. y wont it work? is there any other avi-mpeg1/2 encoders around? all my other avi files seem to work except this one. its a dvd-rip i downloaded.. i think its XviD codec-=Turbo=- -
Originally Posted by turb0
If its a dvd rip then chances are the quality is not going to be that good when converted to fulls creen at DVD bitrates. I would use TMPGEnc Free Version to convert it to VCD or SVCD standard. You will see what I mean if you continue on and burn to DVDR.If in doubt, Google it. -
is it possible to record it as a svcd onto a dvdr disc? or would it need to be mpeg again?
-=Turbo=- -
Yes, SVCD is mpeg too, and no, you can't create a SVCD on DVD media. Other mpeg encoders are MainConcept and CCE to mention a couple. When TMPGEnc and your system is set up correctly, TMPGEnc has no problems with XviDs or most other AVIs. For really stubborn files, you can rely on opening them in VirtualDub and frame serve to TMPGEnc.
Keep reading the guides/articles found under Convert left, the AVI to DVD/SVCD section, and try some methods described there.
/Mats -
i think my avi file has compressed audio wat does that mean? how would i convert it now and what would i use? got any guides?
-=Turbo=- -
Almost all AVIs have audio in compressed format. It may be mp3 or AC3, but other encodings can be found too.
If AC3, TMPGEnc can't handle it directly, so you have to extract the AC3 track with VirtualDub and convert to WAV. Or you can load the AVI in GoldWave, and save audio as WAV if your system has the right codec installed.
As for guides, make a search on AVI to DVD under Convert, and read, read, read. None is going to hold your hand from start to finish!
/Mats -
virtual dub sed:
could not locate decompressor for XviD codec
wats that?-=Turbo=- -
Hey turb0,
everytime i add the .avi file to convert it to dvd in TMPGEnc it says: "filename" cannot open, or unsupported..
https://www.videohelp.com/tmpgenc.htm#problems
The site administrator doesn't want this site closed down, nor do the many many people who have benefited from it. Violations are regularly reported by general users.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hey turb0,
Cool - Sounds smart. Good luck and I hope you get to enjoy it on your DVD.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
A last resort (IMHO) is to use the fourcc changer. Change all occurances of XviD to DivX in the AVI.
/Mats
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
Philips DVDR 7260H Hard Disc Crash
By ikcdab in forum DVD & Blu-ray RecordersReplies: 3Last Post: 27th Apr 2010, 22:58 -
AVI Files to DVD data disc
By rossco3333 in forum Authoring (DVD)Replies: 6Last Post: 27th Oct 2008, 07:20 -
Cant burn on -dvdr disc
By dnst3 in forum Newbie / General discussionsReplies: 11Last Post: 20th Dec 2007, 01:46 -
CHEAP Dual Layer DVDR Blank Disc @ Best Buy: I can't find that thread again
By Scooter_NJ in forum MediaReplies: 9Last Post: 11th Oct 2007, 15:42
