for some reason, the capture I did last night has really loud sound, is there any way to reduse it?
Results 1 to 13 of 13
How is the audio getting into your computer and/or capture card? Is it using your sound card as audio input? If so, just adjust your record level settings in "Recording Control" in Windows.Originally Posted by Amaze
If its an avi file you captured to then open in virtualdub and set audio to full processing mode and set the volume to the level you want and set video to direct stream processing and save avi as..
Here's a typical command line to convert an audio file.
The '-ota( -g max )' command 'normalises' the volume, try this first, if it's still too loud then try reducing the volume by changing the value 'max' to a negative decibel value,Code:"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input audio.mp2 -output audio.mpa -logfile audio.log ) -ota( -g max ) -ssrc( --rate 48000 ) -2lame( -e -b 224 -m s )
eg '-ota( -g -5db )'.
Also change the other vlaues to suit your file (rate, kps, input file, output file etc). -
thanks, I tried your code, wasn't really any difference, I'll try the negative decibel value now...
thanks a bunch, with -15db it was back to normal...I have no idea why it got so loud in the first place...
Glad it worked.
The audio is normally captured through the 'line in' socket on your sound card, this has it's own volume control separate from the standard PC volume - check this, it's probably set too high. -
that's the weird thing, I've been capturing for a month now, and all of a sudden this one capture got insane sound, I haven't changed my settings before or after, and now it's back to normal, maybe comedycentral had a problem?
My Bass in a Cam Recording is to loud ?
By picklepie90 in forum AudioReplies: 6Last Post: 1st Mar 2011, 01:04 -
Captured audio is REALLY LOUD
By justin81 in forum Capturing and VCRReplies: 4Last Post: 11th Aug 2009, 07:43 -
TV Capture not loud enough
By programm in forum Capturing and VCRReplies: 11Last Post: 10th Mar 2009, 07:48 -
DVD movies Sound effects way loud voices... not so much.
By maxx409 in forum Newbie / General discussionsReplies: 7Last Post: 15th Feb 2008, 12:57 -
Loud Hard Drive
By Nitro89 in forum ComputerReplies: 9Last Post: 8th Feb 2008, 13:40
