Until recently I have been using win 98se and every worked just fine but because of the limitations of 4mb for avi files I decided to upgrade to win 2000 unfortunatly my cd burner doesn't locate blank disc's to format or to write to.I was wondering what cd packet software works under Win 2000.previously I used WinOncd + Packet cd and it worked fine under Win 98se but not with Win 2000. Any help would be very much appreciated.
Regards: Patsym1
Try using the aspiinstall.exe on your ez cd creator disc, I am in Xp and it works fine, just dont use the web version, it gave me some error.
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 14:17 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
DVDDecrypter work in Win XP Pro x64 w/ external drive?
By redsandvb in forum DVD RippingReplies: 8Last Post: 14th Jun 2009, 19:15 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51 -
Win XP installed on slave drive!!! How???
By rijir2001 in forum ComputerReplies: 7Last Post: 4th Sep 2007, 09:25
