Is there a way to stop that annoying freezeing that happens when the scenes change.
Im recording my shows I taped on video onto dvd. Im recording in Dolby Dig. I then cut out the commercials and then place a chapter marker at all the comercal spots. Now when I play back the show on the recorders HDD there is no Noticable freezing. But when I transfer to DVD-R then watch it freezes for about a sec at the start of each chapter!
Dose any one know a good way around this? it also freezes when I play the DVD-R on my other normal DVD player!
Thanks for the time!
I have a DMR-HS2, and my settings are:
Hybrid VBR Resolution: Fixed
Still Mode: Automatic
If you are going to transfer from the standalone to the PC, then you would want to used Fixed. This will prevent future headaches.
Recording at XP or SP should lesson the blocks in the black area. I don't know of any other settings that will, as I don't have your model. But, there maybe for you.
Tearren -
Just to let you know what I learned in different post.
Originally Posted by fscroccoPinnacle Studio 8 and DV home video editing (ver.9 already home) -
I would say to maintain the best compatibility in the future when transfering video to the PC, change the setting to "Fixed".
The setting only refers to the resolution. This will not decrease the quality any, the encoding will still be done in VBR mode.
Tearren
Video to iMovie from Panasonic DMR E80H
By cjc182 in forum MacReplies: 0Last Post: 20th Jan 2012, 20:20 -
Panasonic DMR-E80H issue
By mavphoto in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Jun 2010, 20:10 -
Panasonic DMR-E80H Error messages
By JeffM in forum DVD & Blu-ray RecordersReplies: 38Last Post: 7th Oct 2009, 18:08 -
Panasonic DMR-E80H not able to record sub stations
By chrisincent in forum Newbie / General discussionsReplies: 9Last Post: 15th Apr 2009, 13:57 -
Panasonic DMR-E80H Setup
By thebrookela in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Mar 2009, 15:37
