I converted a WMV file to a AVI file using the STOIC converter found on this site. Afterwards, I converted the AVI file to a VCD with the AVI2VCD converter (also found on this site). Then I burned it onto a CD-RW and tried to play it in my dvd player(Apex AD-1500) but there was no sound. I thought that maybe I made a mistake so I tried it again and the sound was all jumpy. Any help would be appreciated. Thank you.
~~Raven 1~~
*AKA- RSW* -
Sounds like after changing the WMV to AVI you need to check out the audio track and see if it is compressed. Most likely it is, then you need to go back to the site where you got AVI2VCD and use the decompress.exe tool to decompress the audio. Then you shouldn't have any problems, just keep the audio rate within compliance for VCD.
Okay, I tried what you said to try, but that did not work either. Should I just get another program?
~~Raven 1~~
*AKA- RSW*
Forum is 'Jumpy'
By olyteddy in forum FeedbackReplies: 6Last Post: 18th Nov 2010, 22:09 -
DVD is jumpy after conversion
By RebelUK in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 29th Jul 2010, 13:04 -
Avi to dvd jumpy..?
By Mozzy31 in forum Authoring (DVD)Replies: 7Last Post: 7th Feb 2010, 04:05 -
Jumpy jerky mp4's
By zinc in forum Software PlayingReplies: 3Last Post: 13th Dec 2008, 15:15 -
Jumpy DVD ?
By Dash1 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2007, 14:53
