I know this recorder is supposedly equipped with firewire... What exactly is it?? and what is it's purpose??
Curious![]()
It transfers both video and audio together on one cable in digital form, so there should be no quality loss as with analog connections. Theoretically, anyway. In many real world cases however, I see little difference between a firewire and s-video cable, so it's no great loss without firewire.
The 60 and 100 both have the firewire connection, not the 80, unfortunately (I have the 80). The firewire is used to connect your DV camera to the DVD recorder so you can transfer your home movies from DV to recorder's hard drive and then to DVD.
No it does not.Originally Posted by Infiniti2004
BTW: Did you try this ? https://www.videohelp.com/glossary Link on the left
(FireWire is also known as iLink or IEEE 1394)Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
If your Digital cam has analog output (which it should) then just use that with your DMR-E80 and don't worry about it (the DMR-E80) not having FIREWIRE.
I've seen enough tests that show little difference when you record analog out VS firewire out when you are encoding direct to MPEG-2
So it's no big deal.
Panasonic DMR-E80H issue
By mavphoto in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Jun 2010, 20:10 -
Panasonic DMR-E80H Error messages
By JeffM in forum DVD & Blu-ray RecordersReplies: 38Last Post: 7th Oct 2009, 18:08 -
Panasonic DMR-E80H not able to record sub stations
By chrisincent in forum Newbie / General discussionsReplies: 9Last Post: 15th Apr 2009, 13:57 -
Panasonic DMR-E80H Setup
By thebrookela in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Mar 2009, 15:37 -
Panasonic DMR E80H problem when recording..
By Gravelexpress in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th May 2008, 10:36
