I have both EZ CD Creator 6 and Nero Burning ROM 5.5. Can I intall these to applications to one computer? I will run only one of the application at a time. Does any one advise me?
Kinlun Yu
Nero will not install itself if it detects Easy CD Creator, that simple.Originally Posted by kinlunyu
Nero has a patch that provides dual install but requires boot selection for one or the other.
Directcd IS compatable with Nero but not with incd -
That's not quite true.
I have had EasyCD Creator 5 and Nero 5.5 installed on the same PC with no problems. Nero does not refuse to install and they do not interfere with each other.
Of course I don't install DirectCD or any other optional components.
Different version of packet writing software will probably interfere with each other but the basic programs are fine.
I can even use the WindowsXP built in CD writing support with both other programs installed.
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 11:29 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2007, 00:54 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
Burning multiple copies of a project using Audio DVD Creator
By scratcher in forum AudioReplies: 2Last Post: 28th Sep 2007, 17:28
