Given scenario - No computer, however : dvd player + tv + vcr(video) + a range of different cables and empty vhs/svhs cassets(tapes).
Desired outcome : to succesfully copy a dvd movie to a simple video tape.
1)There is probably some scrambling, so - is there a need to buy some "magic" box ? (usually you plug the outs into such a box and the ins from such a box goes to a vcr, and - tada, no scrambling or other protection and the copying procces can be done).
Basically what I'm asking is - is there someone there who knows what I need to do ?
Thanks in advance,
TDO.
the scrambling you refer to is macrovison and look up your dvd player and see if there is a hack for your model or you could get the "demacro leads" to conect your equipment together from a good reputable dealer
links on the left
<<<====It appears that the CPU was operating so fast that it began to execute instructions before they arrived. This execution of future instructions created a small tear in space-time itself through which part of the cpu passed into a parallel universe -
as the previous poster mentioned, what you are referring to is macrovision. What you will need (or hope you own) is a dvd player that can be demacrovisioned. An excellant example would be the apex 1100w (info available at nerd-out.com). If you can demacro your player, then all you will need to do is hook your dvd player up to your vcr and record.
I did this with my apex, however, never did it for the purpose (and have never tried it) of recording dvd to vhs. Mine was because I was too cheap to buy a rf modulator and ran everything through my vcr to my coax cable only tv.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
