I use Tmpg plus to convert .avi to .mpg but i can never seem to get the picture size just right. Either the sides are cut off or everything is stretched vertically. Can anyone explain to me a way to get the normal picture size or what the settings mean when you can choose between wide or full screen while in the wizard mode? Thanks in advance.
You can always test all settings in tmpgenc and use the file->preview to see how it looks. For downloaded avi files(divx/xvid...) I always use 4:3 and under advanced 1:1 and keep aspect ratio.
TMPGenc settings explained:
http://dvd-hq.info/Compression.html
video formatting/ picture size
By rocks911 in forum Video ConversionReplies: 4Last Post: 7th Dec 2011, 18:47 -
picture size difference after transcoding (TMPGenc 2.5)
By jakewoodblues in forum Video ConversionReplies: 12Last Post: 27th Apr 2010, 20:57 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
Vista Media Center Live TV Picture Size
By jbartosh in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Aug 2008, 15:59 -
How to change picture size
By hilario in forum Video ConversionReplies: 18Last Post: 24th Mar 2008, 08:04
