Hi all, trying to rip disney dvd, but audio is a few seconds in front, used smartripper etc, & used eazy vcd & its the same in both, not had this problem with no other dvd, read somewhere to use mpeg tools in TMPGEnc to demux & remux??? help!!! is this right & which tabs, details do I use??![]()
Thank you.
I am assuming you are working with an MPG file. You could try demuxing but that might not be the problem. Open MPEG tools and click the Simple DEMUX tab. Load up the mpg file. It will create a seperate output for each audio/video stream. Run. Then clikc the simple multiplex tab and load the 2 streams to save the MPG file(basically reversal). Your just taking apart the file and putting it right back together to fix any header or other problems. If that doesn't fix it you may have to figure out where in the file the audio becomes out of sync. Does it do it all the way through from the beginning? Does it go off at a certain point later in the file? This will determine whether you have an error or not. If it is off from the very beginning then can demux the file and use BBMPEG to mux it. This way you can set an audio or video start delay(experiment with it) to get them in order. Make sure it isn't a media player causing it on playback(media player). I usually open my mpeg file in FlaskMPEG to test because it always plays the file back properly if the media players dont.
Hope this helps some.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
