  1. Hi-
    I have a 10 minute video I would like to burn as VCD, but I also wanted to burn additional files to the CD for computer use, would they conflict with one another?
    I want to give the possibility for computer users to view the video as well, so I was planning on having an MPEG1 file on the cd (figured its most compatible). I am planning on setting up an Autorun file which will load a small image with the option to watch the video or view a slideshow.
    I was just wondering if having an Autorun file set and all the other files if they would interfere with this cd playing on a DVD player?
    I'm kind of new to this topic and would appreciate any help.
    Thanks in advance, Chaim
  2. Member DVO's Avatar
    Apr 2002
    I'm not sure you can use autorun on VCD for the PC files (I don't think so), but you can put "PC" files on it in a folder with VCDeasy. It's free to try.
