i found a website that offers labels to download for free, but I dont have any ink in my printer, so im gonna get some and then play with it tomorrow. But my question is.... is there a program or some way to easily print these things? I download a jpg of the disc, but how do I print it out and get it centered up nicely on the labels?
Results 1 to 23 of 23
I use the memorex labeling system. Has an applicator to ensure that the labels are centered. Dont use cheap labels.
The Memorex system comes with CD LabelMaker software.
Make sure you allow enough time for the labels to completely dry.
No, you cannt apply the label by hand without an applicator. -
I don't use the disc labels (fear of imbalance or not playing) but I do create covers for DVD's that fit a regular CD case. I find it saves a huge amount of space for backups.
You can write custom reports (and covers) using the DVD Profiler program which categorizes and tracks DVDs. It includes free cover artwork, stars, times, release dates, and a ton of other stuff. You can find it at www.intervocative.com. A great program for those with a lot of DVD's. -
I have created over 300 labels for CD's/DVDs total and never had an imbalance problem. Where did you hear that from or did you just think of that?Originally Posted by JayhawkAdam
DVD Decrypter>DVDShrink>CopyToDVD -
Do a search on DVD labeling on all the forumsOriginally Posted by AdamRA4
Some people have problems
Some people don't have problems
I've only done 1 and it seemed to work OK on my puter and standalone -
What is the website that has these labels available for download? That would be NICE. Thanks.
As noted by STILTMAN I have read a number of posts from people that have had problems. Some were no doubt player-based, some probably type and quality of labels but regardless, I just don't want to take the chance. Since I normally play one DVD at a time then put it back in the case, there really isn't any need for me to label the actual DVD.
I did read one article (not a forum post) regarding certain label glues deteriorating over time. I will try an find the article and post it. I remember it being more related to storage method (case, temperature, etc.) but still it's worth considering. -
Actually the quality of label art is much better at DVDCOVERART.com. Unfortunately they charge 10 cents a label (or used to anyway). I used to use them but haven't in several months.
Play it safe. Use Hub / Core labels for your DVDr's.
True, many say they don't have a problem, but many do.
While the hub label does not offer a lot of room for logo's and text, it does reduce the risk of wobble and less mess if you need to take the label off. Plus they are dirt cheap! 520 for $10.00
http://www.labelgear.com/LG/Product.asp?ProdCode=20006-21116 -
If anyone knows wher we can get those hub labels here in the UK (without buying "full face" label kits and throwing away 90% of the whole kit), please let us know...
garryheather,
Click on the link above (labelgear), then click on the globe icon on the upper right. That will give you info on international suppliers of the hub labels. -
DittoOriginally Posted by grossjamesh
I`ve made tons and have never had a problem.The program is extremely easy to use. -
Wicked-N-Twisted
I often wonderif I am doing something wrong.
My capture card works great.
My DVD software works great.
My computer works great.
Windows XP Home - no problems.
DVD labels no problems.
I just must be doing something wrong -
I use Fellows NEATO labels. They are a sticker. So you really cant have an unbalanced disc because of a label. You are not putting on your own glue/adhesive for the label to stay.Originally Posted by grossjameshAdam
Save your cash and get a quality CD/DVD printer. I use Ritek ink jet printable disc with an Epson Stylus Photo 900. If used properly you can not tell the difference between the copy and most originals. Shop around you can always find the 900 for under $200.00 and some times you can get a rebate. I ended up spending under $150.00 for mine. Once you get the setting correct it prints very close to the originals quality IMO.
Then I print the insert art on photo quality glossy paper I get from Costco with NERO cover designer software. This is one of the few things I think NERO does well. Cut and put the insert in a supercase and Walla, copies as near as possible to the original. I am working on a short guide for proper settings with the Epson but have not finished or posted it yet.
Links just as examples of the above mentioned products and procedures. You can find the hardware and expendables all over the internet and in most computer stores.
Printer
http://google-cnet.com.com/4014-3157_9-21155096.html?part=google-cnet&subj=900_epson_p...ylus&tag=Color
Media
http://www.shop4tech.com/user.htm?go=view_item&id=1806&cata=1&s_cata=88
Supercase
http://www.shop4tech.com/item1245.html
Supercase Inserts Guide
http://www.dvd9to5.com/DVD_Inserts1.htm
Me
http://www.dvd9to5.com/startframe.htm(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
I personally wouldnt bother with CD/DVD labels... Overheating of the disc causes the glue to become loose, which could cause the actual label to get stuck in your machine. Ive seen it happen, and its not worth the potential headache. A good ole' sharpie or CD labeling pen does a perfect job.
Originally Posted by Roll Tide
Nice try, but "Surething" are not - they only do the full face labels which aren't an option (too much wastage by far).
Any other ideas / suggestions ?
Come on UK retailers, why are hub labels so difficult for you guys to source ? -
It seems this has all the good questions do you or don't you?
I have been printing these labels now for nearly 2 years back in the days of vcds and yet to have any problems so give it a go if you want to spend some money. -
For those of you looking for hub labels in europe look here http://www.neatoeurope.com/nt_products_EN.php?sgid=49&lang=EN
they cost € 4,95 for 100 sheets with 20 CD Core Labels Per Sheet. -
i also say stay away from cd/DVD labels
they do have a tendancy to start peeling off at the edges and get stuck
or even pull off the silver coating too which makes the dvd unreadable
that sounds good with the printer will be checking that out
Question about CD/DVD labels
By tcory in forum Newbie / General discussionsReplies: 10Last Post: 12th Mar 2011, 11:08 -
DVD labels
By Ogilvy in forum MediaReplies: 18Last Post: 19th Dec 2009, 22:37 -
New printer for DVD labels
By cobra jet in forum MediaReplies: 13Last Post: 18th Nov 2008, 09:39 -
CD / DVD Labels - Which ones should I get?
By jcm0320 in forum MediaReplies: 4Last Post: 15th Dec 2007, 22:01 -
CD / DVD Labels
By wesmoc in forum Newbie / General discussionsReplies: 6Last Post: 7th Jul 2007, 08:42
